PIN Number access - I know it's a tautology
A project log for 2FA_Sidecar
A Mini Keyboard that types two factor one time passwords for you
matt-perkinsMatt Perkins • 06/20/2023 at 10:17•0 Comments
Version 1.10+ has an optional 4 digit identification number  for access. A 4 digit PIN can be added from the setup screen and then when the sidecar boots up it will ask for the PIN before you can access the two factor tokens. An incorrect pin will reboot the device and ask again.  The delay can be set in includes if needed.
Matt
