Your GTW0 is the one which is connected to internet and which synchronizes the weather station (and other GTWs if a wider Rezodo network is in use).
To configure the GTW0 we have to set up the Wifi credentials and the frequency of sensors measurements.
This is done by touching the TP1 pad on the PCB and (while touching the pad) resetting the ESP32
Then a web access point will pop up on which you can connect your smartphone
Connect to this hotspot then enter
- a valid wifi ssid and password
- the frequency to wakeup your weather station in minutes
that's it !
JP Gleyzes
