3D Printed Vibrating Saddle
I have repaired and hacked more than a few Sybian's over the last few years and decided it was time to design and build my own.
For those who do not know what a Sybian is they are a vibrating platform used in the Kink environment. Mostly they just work but are not an inexpensive device. Using what I had learnt from the many repairs I have done on both the originals and the clones I decided to design my own platform.
Most of the mechanism was printed on a 3D printer, the silicone appliance for the top was cast using a 3D printed split mold, the bearings, main shaft. retainers were made from Steel and Brass. The motor came from a 14.4V Cordless Drill.
Speed controller was made using a IRF540, Opto Isolator and an Arduino Mini Pro.
There are two modes, the first being free running where the unit outputs a constant vibration, the second mode is a kind of ramp mode where the motor is ramped up and down to level set by the pot on the pendant .
First Test of the Mechanisim
Final Test with the new pendant and mode settings
Adobe Portable Document Format - 440.72 kB - 12/29/2016 at 22:12
Preview
Download
CamShaftandPulley.pdf
Details on the Camshaft and Pullie
Adobe Portable Document Format - 290.33 kB - 12/29/2016 at 22:10
Preview
Download
The Finished Item, assembled and ready to go.
JPEG Image - 2.22 MB - 12/29/2016 at 22:00
Preview
Download
  • 4 × Scateboard Bearings
  • 1 × 12 Volt Motor (I used a salvaged motor from a cordless drill)
  • 1 × Arduino Mini Pro
  • 1 × IRF540 Discrete Semiconductors / Power Transistors and MOSFETs
  • 1 × Optoislator
View all 10 components
View project log
mauro_12345 wrote 11/17/2023 at 15:42 point
it's possible view the video?
ebonwingb wrote 06/02/2021 at 16:11 point
I hope this project hasn't been abandoned and the STL files lost.
Boris van Galvin wrote 02/09/2022 at 20:26 point
https://cults3d.com/en/3d-model/naughties/vibrating-saddle
Strrinng wrote 02/26/2021 at 12:47 point
hello, can someone please explain how the motion and power gets transferred here to me ? I just see a shaft and multiple bearings so i Dont see how anything of the upper Bart would move. Is there a execntric Part i an missing ?
Boris van Galvin wrote 02/09/2022 at 20:25 point
On the left (in the first picture) you can see a smaller pulley (brass) and that connects to the larger 3D printed pulley on the left of the motor I excluded the belt in the picture.
Mick wrote 01/20/2021 at 19:25 point
What about the STL files..? Are they available?
jefferycorreia wrote 10/27/2020 at 21:17 point
we’re to get the STL files
Boris van Galvin wrote 02/09/2022 at 20:29 point
where can I get the STL files?
John Scancella wrote 04/29/2020 at 19:13 point
Are the STL files available?
tom edington wrote 05/21/2017 at 10:43 point
Where do you get the cam shaft for this project?
Boris van Galvin wrote 02/09/2022 at 20:28 point
I made my one up. well have actually made a few now using a lathe and a spacer to offset the shaft ends. I have heard of a few people fabricating it using bolts but never heard back as to how well this worked.
