Solder paste?
A project log for Focus
A compact and standalone board, programmable via a simple Visual Language inspired by the normal electric schematics.
chmod775chmod775 01/02/2017 at 21:196 Comments
Well, it's better to say 'Solder Mess'!
The board 'face' in the middle is worth a thousand words.
First ever try using solder paste and hot dryer gun.
Michele Perla wrote 01/26/2017 at 10:13 point
dude you put a bit too much solder paste on the QFP pins, you are going to get some solder bridges. That technique works but you should use a smaller nozzle. Also you may want to put more paste on the bigger pads. Finally, for manual reworks you may want to consider using a lower melting point paste like the Quikchip one, it's easier to work with if you're using a hot air gun to reflow the boards.
chmod775 wrote 01/26/2017 at 17:27 point
Thanks man for those, very very useful, tips! I'm really enjoying some of your projects. Are you from Italy as well?
Michele Perla wrote 01/26/2017 at 17:29 point
Yes! Italian hacker currently based in France :)
Yin Zhong wrote 01/26/2017 at 02:09 point
Wait... OSHPark does MicroUSB plated slots?! I have been inflating them to round PTHs... Gonna try doing that some day!
oshpark wrote 01/26/2017 at 02:50 point
Feel free to email support@oshpark.com and our support engineers can give you tips.
chmod775 wrote 01/26/2017 at 07:11 point
Yes, and they does it very well! I was worried too. Fell free to contact me if you want the eagle part library.
