removed the emergency pushbutton
A project log for 1 KB 6 legged crawling bot
the robot is controlled with an arduino nano and only uses 2 motors and 2 sensors. The program to control the robot is only 843 bytes big.
brian-brockenBrian Brocken 01/02/2017 at 23:200 Comments
I removed the emergency pushbutton. This button was to prevent the robot from demaging itself during testing. You can see the two red wires that go to the pushbutton in the pictures.
