Dock design and build
A project log for Stargate LED Clock
An LED clock using the adafruit 1/4 sections to make a 60 LED ring. Although not a new concept, it should be expandable to other variations.
david-hopkinsDavid Hopkins 10/06/2014 at 15:361 Comment
after thinking through a few options i came up with a simple dock that would hold the gate in place at an angle and not protrude too far from the top of the base... this is needed so that it can be boxed up and not be too flimsy.
Design turned out thus:
the base was also modified to accommodate this, the socket for the gate put in place and the light sensor (which i had previously forgotten) put in as well:
and now the dock in place to show mechanical fit:
next stages:
- finish spraying grey (already started, but rain is reducing opportunity to do so)
- spray with varnish
- mount dock
- wire up electronics
- try to fix the 'tripping' seconds issue (possibly due to RTC updates during fade effect)
rinondavid wrote 04/04/2019 at 06:23 point
Blogs are created with good ideas and language helps the readers to improve language and also the thought. This has every important point and the topic selection is very creative. Each article has unique and specific qualities to its type. We can see some same characters in all articles. Writers get chance to share important and compelling information by researching and forming writing idea and editing work to the readers. You have done a great work. I really enjoyed your posts. Keep writing different type of article with all the important details.
Refer: https://buyessays.us
