Looking at some of the SG models around the net, most have ramps or the bottom of the gate is obscured so people can walk in/out of them. all makes sense but not suitable for my version... so what im creating could be called a 'themed stand'.
it will have a power socket and 3 buttons; the base will be removable in-case any adjustments need to be made. this will probably be held on with neodymium magnets, but we shall see.
Picture time!
close up of the button board:
inside of the base/stand:
base and sprayed gate (the back and sides of the gate will be generic grey)
stand & gate, now with SG printout stuck on, trimmed and touched up where needed, also the led ring is sitting in its slot, but no wiring as yet:
the base will have stone effect stuck on and, like the ring, all be sprayed with polyurethane varnish to protect it.
just need to find some stone textures now.....
David Hopkins
