Pretty-fying the base/stand
A project log for Stargate LED Clock
An LED clock using the adafruit 1/4 sections to make a 60 LED ring. Although not a new concept, it should be expandable to other variations.
david-hopkinsDavid Hopkins 09/26/2014 at 07:390 Comments
After hunting around for stone textures on the net i finally found a few, and with a bit of help settled on one of them, printed A3 size, and stuck it on. Hmmm, sounds simple, but there was a lot of carefull work with a scalpel and marker pens to tidy up the white edges of the paper.
efore colouring in:
 and after:
next stages:
-decide on how to mount the gate (currently pondering a 'dock' style design)
-lacquer the gate (sans LEDs) and the base as it is
-add a mounting hole on the front of the base for an LDR (forgot last night)
