This is probably much simpler and cheaper than the previous approach. A 20 x 0,5 mm copper strip is connected to a 4 mm2 standard solar cable with a crimped-on ring ferrule. Everything is protected by a 3d-printed case for isolation and strain relief.
Joris Wegner
