Adding boards to this project
A project log for Small PCBs for panelizing + tutorial
Ordering a 10x10 board with only 10x4 taken? Panelize one of these!
AryaArya 05/09/2017 at 00:102 Comments
  1. Please, please, upload gerbers, in a ZIP - don't make others generate gerbers for you. I don't have Eagle installed, for example, and thus can't generate gerbers from Eagle - and gerbers is the universally accepted standard. After generated, ZIP them up, check them here and then upload them to "Project files" section or link them in the project comments, I'll take care of the rest =)
  2. Having a description would be awesome. "SOIC-8 breakout" is a good description, "Power rail breakout" is not, unless you provide pictures/link to online viewer - and "0.1in header power rail breakout - 3x10, 3 rails" + picture is just great! (sometimes, linking your Hackaday.io project is sufficient if it's about the board in question)
  3. If possible, and I really hope you do that, please include source files - GitHub link will be great, too.
This is a good example of a board description for a board with active components that actually does something useful.
Thank you for contributing!
davedarko wrote 05/09/2017 at 06:02 point
you could have said something :p
Arya wrote 05/09/2017 at 12:02 point
Hey, that's not about you, I was going to go through your boards yourself =) Sorry it looks that way, I just took it as an example because I understood this would be kinda hard to manage.
