What is panelization and why is this the awesomest thing for a hobbyist ordering boards?
A project log for Small PCBs for panelizing + tutorial
Ordering a 10x10 board with only 10x4 taken? Panelize one of these!
ArsenijsArsenijs 05/09/2017 at 00:135 Comments
PCB panelization is a nice way to get more bang for your buck, be able to do more projects at the same time and, in general, receive more boards at once. Say, you have two 10x4cm boards, and a seller offers you to either take . You could order them separately, as two 10x10cm PCBs (10x5 at best), or you could merge them into one panel.
Panelization means merging together PCB gerber files in one gerber. The main problem that needs to be solved is that you can't just put boards together - they usually need to be connected somehow. They also need to be easily splittable once you receive them - you won't want to split them using a cutting disk =) There are two main ways to panelize boards so that they can easily be split - V-grooving and tabs with mousebites. "Tabs&mousebites" means - connecting boards using tabs, they're added in between boards and are basically pieces of PCB material connected together (mousebites are holes drilled in tabs so that it's easier to break them off). V-grooves are cuts done with a machine with a cutting disk, that cuts lines through PCBs, leaving them connected but just barely, so that you can snap the boards apart.
V-grooving (failed) - picture from somewhere on here
Tabs with mousebites (inner area is not actually filled) - picture from here
There's a problem, though - not all PCB houses support panelized boards. There are houses which are panelization-friendly, there are those who will ask you to pay extra per ech individual design on panel (and usually it's so much money it's not worth it), and there are those that flat out don't work with panels. Some only support V-grooving, too. Check your PCB house. I'm using DirtyPCBs since they're panelization-friendly, doing tab panelizing for free and V-groove for additional 5$ (as of 9 May 2017) (minumal V-groove length is 8cm), and also for the fact that, in my experience, they're actually maker-friendly and not just somebody doing business.
Ken Yap wrote 08/18/2019 at 09:42 point
Can we start a discussion about which fabs are panel friendly and which not?
To start off here's my reading of JLCPCB's stance. Their web page is a bit ambiguous about the issue:
https://support.jlcpcb.com/article/49-pcb-panelization
On one hand they say:
1. Note: This additional charge only applies if the PCBs on a panel are different. Boards such as in the left hand image below will not incur an additional charge because they are easy to pick up but boards such as in the right hand image would incur an additional charge.
On the other hand before that they say:
2. Similarly, using holes or slots as break off sections between boards are treated the same way as putting more than one design on a panel, each with its' own board outline.
Then they go on to suggest drawing some lines on the silk screen so that you can separate them yourself, but this would require me to have a dremel.
So which is it? If I use slots and mousebites to put 2 of the same design inside 100x100 mm, will they invoke rule 2? I suppose I could submit it and see what their sales engineers say.
Amos wrote 08/18/2019 at 10:07 point
I haven't (yet) had a problem with putting multiple different boards on a single panel (with mousebites) when ordering from JLCPCB - they haven't charged me extra for multiple designs. Maybe I just got lucky, but I have had several orders go through okay with no extra charges. ¯\_(ツ)_/¯
Ken Yap wrote 08/18/2019 at 10:14 point
Ok, maybe I'll give it a go. Maybe in these straitened times fabs won't be too picky about taking a job.
Arsenijs wrote 08/21/2019 at 18:47 point
DirtyPCBs is very panel-friendly, in my experience - I've been ordering panels from them for many years, however, their 10x10 does cost $16. With JLCPCB, however, I would expect to get slapped with additional charges, as I use panelization heavily. These aren't experiences, just expectations, and they do tell you that they will check your design before sending it off to be manufactured, requesting additional money where applicable. I do expect JLCPCB to have *some* leeway - hence the "JCLPCB-friendly" panels for ZeroPhone https://wiki.zerophone.org/index.php?title=PCB_panels#Delta-B_PCB_panels , these should allow people to save ~$10 on a ZeroPhone PCB order, though not as much as if you were to use DirtyPCBs.
Answering your question - I'd submit the design, then wait for their answer - it's possible it will not really be noticed =) Do report back with your findings!
nadim wrote 02/21/2019 at 15:10 point
Hey. Your program does not work with KiСad 5.0Gerber file does not open. The program falls into error. Can I fix this?
