Glue case together
07/26/2023 at 19:31 • 0 comments![]()
Glued with Araldite epoxy resin (also fills the gap) ![]()
With inner and outer display frame ![]()
With keyboard mount (which is also the 2nd part of the bottom cover (white) ![]()
Testing my new CAD skills: the bottom cover (white) seems to fit with the inner display frame (black resting on the little white feet of the bottom cover). -
Print
07/26/2023 at 19:28 • 0 comments# Print
The printing time for all parts was approx. 20 hours. I printed the case in two parts, so fewer supports were needed and the holes for the mouse buttons and trackpad etc. were printed without any problems. In addition, I couldn't print it out in one go with the Bambu X1C, the case has the dimensions 253x253x104mm and the Bambu actually has a build volume of 255x255x255mm. However, the bamboo has a small area in the XY movement which it cannot use because the filament cutter is located there. Interesting fact, but didn't help me that much.
both display frames ![]()
display frame ![]()
one case side ![]()
one case side -
Design the case
07/26/2023 at 18:54 • 0 commentsStarted with the blue side profile Trackball mount Powerbutton (right) and power led (left) Keyboard mount Outer display frame Inner display frame with raspberry mount. The display (pink) sits between the outer (yellow) and the inner frame (blue) Rotary knoob Without cover Both display frames All parts without case and keyboard ![]()
rear panel ![]()
IO panel
