| Title | Date (created) | Blurb |
| some entries were finished and first published later than this date some entries (like this one) reflect ongoing accumulation and/or revision | ||
| Warm PLA sag: accidentally not really a problem | 29 June 2026 | |
| OT: MRRF is dead, long live (not)MRRF! | 27 June 2026 | Fourth and last visit to MRRF. |
| yet another little differential gearbox | 29 Nov 2025 | a widget demonstrating small spur gears |
| Workholding | 21 Aug 2025 | hold work with screws instead of tape |
| A better Z axis that's actually better | 9 Aug 2025 | revised Z axis, ready to build |
| MRRF 2025 | 24 July 2025 | third visit to Midwest RepRap Festival (next three entries with later dates describe work done (mostly) before MRRF but not (finished and) written up until written up until (much) later) |
| On making a "simple frame" simply | 7 April 2025 | make a simple frame for the X+Y and Z parts |
| Discord: active and productive! | 27 Jan 2025 | |
| One minute video | 15 Jan 2025 | haven't made an eye candy video since 2dc days -- here's a quickie with current hardware |
| FR-2 = "wood" for very fine detail | 13 Jan 2025 | neat material discovery |
| Thumbnails are the windows to ... scale modeling | 25 Nov 2024 | |
| circuit milling: 0.05 mm (2 mil) trace/space | 13 Sep 2024 | crazy-fine-pitch Cu isolation milling |
| Newer Z is gooder | 3 July 2024 | another Z axis that almost replaced the first published version |
| Meh. New Z is fail. | 3 May 2024 | not the next Z axis |
| Thicker Brass bis: Made a Thing | 21 Feb 2024 | Completed milling a nontrivial object from brass |
| Build? Start here. | 6 Feb 2024 | A place to start. Intent is to maintain links from here to evolving content. |
| Jolly Wrencher 2023 | 1 Jan 2024 (UTC? cuz it was still 2023 in my locale :-/) | |
| Thicker Brass | 10 Oct 2023 | |
| doors again: current and (maybe) future | 8 Oct 2023 | |
| feature creep vol. {n+=1}: doors | 7 Oct 2023 | |
| about runout | 2 Oct 2023 | |
| to shrink, or not to shrink, that is the aggravation | 26 Sep 2023 | |
| Z axis parts & assembly notes | 25 Sep 2023 | |
| XY stage assembly | 19 Sep 2023 | |
| Parts to get started | 17 Sep 2023 | |
| STLs 4 XY & slicing | 12 Sep 2023 | |
| a note about cable management | 6 Sep 2023 | |
| Teaser: 0.010" slots in 0.020" slots in 0.040" slots | 1 Aug 2023 | new tiny end mills cleanly cut tiny slots in aluminum and, incidentally, usefully small backlash |
| MRRF 2023 | 29 July 2023 | to Midwest Rep-Rap Festival with a microscope links to neat drone fly-thru vid |
| closer to all-in-one: first try building in new box | 27 July 2023 | toward integrating accessory stuff that could be integrated into a compact enclosure but wasn't long; lots of pix |
| Whence this project? | 27 July 2023 | ...from a symbiotic pair of projects-in-progress, spawned a new thing different enough to warrant a new project and HaD Prize. |
| this | 25 July 2023 | Because #Minamil 2dc: a minimal CNC mill has accumulated enough log entries to be difficult to naviigate, ̶I̶'̶l̶l̶ ̶d̶r̶o̶p̶ I dropped this here to stake out space for a Table of Contents in case logs here ̶g̶e̶t̶ got unwieldy. |
table formatted table of contents inspired by @Vijay; just chronological for now - because I want at least this for myself sooner than later - maybe add topical structure later... (meanwhile, "Build? Start here" is a topical node)
Paul McClay
