I have an interesting picture, Felini is debugging for its sibling, Felini hardware v1.4. The new version has a small error on the axp192 pmic ic, I mistakenly bought the axp192 version without 3.3v output at dcdc1, so I need a little trick :v
A project log for Felini - Revolutionary Pocket-Sized Electronic Lab
Extremely affordable pocket-friendly, designed to provide a wide range of hardware testing and debugging functions in a compact and low-cost
