Reflection Delay - Nope
A project log for Water Waves To Sound Waves
The waves on water in lakes, rivers, swimming pools, and oceans might sound interesting if recorded and then sped up to become audio waves.
smokeyvwSmokeyVW 01/04/2017 at 16:162 Comments
Negative experiment result:
I tried to record a reflection of a sound wave off a piece of cardboard. The goal was to see if I could measure the distance to the cardboard by measuring the time between the original squarewave coming from a loudspeaker, and the reflected echo. The first few tries, I got no noticeable echo. Finally, by reducing the period of the squarewave, I could see a weak echo in the sound recording, but the return signal was very weak relative to the driving signal. That's going to turn into lots of noise in the software when trying to extract distance info from the recording. So I'm going to abandon this approach entirely for now.
And, more generally, I'm going to abandon using time delays or frequency modulation. I'm just not going to get the resolution I need, given a sampling rate of 44.1 KHz.
Now I'll turn to using amplitude modulation. I'm hopeful this will work much better.
SmokeyVW wrote 01/07/2017 at 15:32 point
I managed to get a reflection at 1 KHz, but I agree that a lower frequency cardboard probably wouldn't work. I used an 8.5" x 11" piece of card stock. That's probably barely large enough considering the wavelength of 1 KHz is around 12".
Starhawk wrote 01/05/2017 at 23:08 point
I'm no sound engineer, but IIRC cardboard will absorb rather than reflect sound. Try a cookie sheet ;)
