This was after putting everything together and attaching the linear actuator. The speed was also adjusted in the code, it automatically increases the speed as it moves forward. It was done for the purpose of increasing the power to push snow. This can always be adjusted in the code if necessary. By changing the speed variable in the "var setup" section of the code.
cele9999
