BOM:
| Part | Number | Cost of each part |
| Power Supply | 1 | $22 |
| Linear Rails | 1 | $60 |
| Linear Actuator | 1 | $50 |
| Bracket Connectors (12 PCS) | 1 | $16 |
| Motor Driver | 1 | $16 |
| 15A Fuse Holder (10 PCS) | 1 | $8 |
| 15A Car Fuse (20 PCS) | 1 | $5 |
| Power Socket | 1 | $8 |
| DC Motor (with sprocket) | 2 | $44 |
| #25 Bicycle Chain | 2 | $17 |
| Roller Chain Detacher | 1 | $10 |
| Gauge 14 wire (200ft) | 1 | $15 |
| #25 Chain Sprocket | 2 | $13 |
| Polycarbonate Sheet (1/4”Thick x 24”Wide x 36”Long) | 1 | $47 |
| 6 Channel RC Transmitter and Receiver | 1 | $37 |
| 1/2" Bore Shaft Collars (4 PCS) | 3 | $10 |
| #25 Chain Connector Link (10 PCS) | 1 | $10 |
| #4-40 Hex Nuts (100 PCS) | 1 | $2 |
| #4-40 x 3/4" Phillips Screws (100 PCS) | 1 | $9 |
| Snow Shovel | 1 | $12 |
| Perf Board (10 PCS) | 1 | $5 |
| 12V Regulator (20 PCS) | 1 | $7 |
| 1/2" x 3' All threaded rod (5 PCS) | 1 | $30 |
| 1/4" x 1' All threaded rod | 1 | $10 |
| 1/2" Hex Nuts (50 PCS) | 1 | $10 |
| 1/4" Hex Nuts (50 PCS) | 1 | $8 |
| Lawnmower Wheels (2 PCS) | 2 | $14 |
| Arduino Nano | 1 | $6 |
| Jumper Wires Female-Female (120 PCS) | 1 | $7 |
| Male Header Pins (20 PCS) | 1 | $5 |
| Insulation Tape | 1 | $7 |
| Assortment Kit (200 PCS) | 1 | $7 |
| Loctite | 1 | $10 |
Final Price for the entire project=$645
cele9999
