Now I am trying to make some isntruction and new code to use it in cartesian coordinate system
You can find STL files at Thingiverse
Lifting power test video:
Distance between base and attaching point: 500mm
Weight: 0.5kg
Lifting power of Tertiarm depends on configuration of spring. In this test I use 4 standart Ikea springs.
anastas.car
Thank you! I will do it soon.
