A long time ago I designed a whole bunch of LED drivers and control systems as part of an ambient lighting system. The company I started to sell them wasn't successful but I held on to a lot of different prototypes and development boards. The system was based around a 2.4 GHz wireless protocol. A typical system might consist of a touchpad based remote control and a receiver/driver driving high-brightness or strip LEDs (all kinds, from white to RGB, RGBA and RGBW).
My partner's daughter lives in NYC and I was trying to think of something to get her for Christmas when I had the idea that her apartment needed some pretty color changing ambient lighting. So I dug through the stash.
The interesting bits include a 4-channel 350 mA constant-current driver (green PCB), a receiver/controller (white PCB) that connects to it using a flex cable, a 5V 3A supply, a HB RGB LED In a heatsink enclosure and one of the original remotes I designed.
I gutted an old halogen track light fixture and modified it to hold the LED/heatsink. It had some plastic bits that could be re-used to mount to a 3D printed base.
A bit of time with OpenSCAD resulted in a simple enclosure that was quickly - well it took 6 hours - printed. I screwed-up the location of the mounts for the driver board but it worked well enough (no-body is going to see that boo-boo).
Then I thought about the remote control. It was always a bit clunky and large because it used 4 AA batteries (one of my first embedded designs...). I decided to hack it a bit so it would run on a USB charger and remain always active.
The guts of the remote consist of a control board and a touchpad originally designed for laptops. To this I added a USB-C breakouts wired directly to the control board and threw together another 3D printed enclosure.
It all came together very well and I was really pleased with the result. The fixture can be set to any color/intensity combination (two of which can be memory presets) or set to slowly change colors on its own.
As I write this the fixture is en-route to NYC. I hope she likes it.
For this project I had everything but a cheap USB charger and 6 foot USB-C cable that I bought from Amazon. The whole project was completed over the course of three days with a lot of waiting for the 3D printer.
Late addendum
I decided to build up a couple more fixtures. For these I bought a cheap outdoor light fixture from a hardware store and re-used the globe and part of the globe mount on a 3D printed base.
Dan Julio
