336 bytes
A project log for sub-512 byte 8-color VGA demo with ATtiny4/5
Generate VGA out from ATtiny5 with 3 pins
Jari TulilahtiJari Tulilahti 01/15/2017 at 23:422 Comments
Assembly complete with no errors.
Segment usage:
   Code      :       168 words (336 bytes)
Bars now slide in and out more nicely, also shrinking code :)
MortenW wrote 01/16/2017 at 15:45 point
That is some serious code reductions that you are doing. I´m guessing that it is just one of those things where you cannot stop thinking about your code, even when you are not in front of your computer. I sometimes have it the same way, just getting a new idea on how to reduce the code or change the algorithms while driving or eating or doing anything else in life.  Keep it up, you will soon find something else to add to fill up the space that you make available :-)
Jari Tulilahti wrote 01/16/2017 at 17:27 point
Hi, thanks for the comment!
Yes, you're quite right! I have about one hour car drive home from work and during that time I already sort of start coding this thing in my head, and I have a really weak spot for tiny MCUs - I've seen enough of those bigger ones at work, LOL.
I'm actually crunching the code to fit something more in there still, like scrolling text!
