Raspberry Pi 5
09/29/2023 at 23:57 • 0 commentsIs this the power button? I want to use it in blockchain camera soon.
Shape of the shutter button
09/20/2023 at 14:32 • 0 commentsThe blockchain camera's shutter button is shaped like the mint now button on the NFT minting website.
September 13, 2023 Object recognition
09/13/2023 at 06:50 • 0 comments![]()
This is what I have done in the past with the blockchain camera and has nothing to do with solving social issues. It recognizes the objects in the photo and adds those as attributes to the NFT's metadata. Attribute is an important element in PFP NFT collections. The rarity of the NFT is determined by the rarity of its attributes, and people enjoy it. I considered whether this could be done with photos. However, the following issues have not been resolved.
- Classify the photographed objects. For example, living things and buildings.
- Attribute combinations must not be duplicated within an NFT collection.
- I need to create a machine learning model. I've used multiple object recognition services, but I haven't found a model that I like.
September 13, 2023
09/13/2023 at 01:22 • 0 commentsThe NFT that Blockchain camera photographs is Real
September 12, 2023
09/12/2023 at 13:48 • 0 commentsI was able to open source the blockchain camera through HACKADAY PRIZE. Thank you to everyone who liked, followed, and viewed my project!
Changed the name from NFT Camera to Blockchain Camera
09/08/2023 at 09:01 • 0 commentsSeptember 09, 2023
I changed the name from NFT Camera to Blockchain Camera.
September 06, 2023 Modification Report
09/06/2023 at 04:15 • 0 commentsI modified the base of the Raspberry Pi Case to make it easier to work with.
Old : RPi_Case_Base_v12.stl
New : RPi_Case_Base_v13.stl
September 4, 2023 Test report
09/04/2023 at 13:54 • 0 commentsI took 1000 NFTs with the Blockchain camera between August 2nd and September 2nd. The gas fee paid for it was 0.617 ASTR ($0.0329). I would like to test other blockchains such as Ethereum. The gas cost and time required to mint an NFT will vary depending on the blockchain.
September 2, 2023 Bug report
09/03/2023 at 04:02 • 0 commentsWhen minting Not Generated #999, the screen display did not change from Minting... to Not Generated #999. But minting was successful.
August 23, 2023 Modification Report
08/30/2023 at 14:16 • 0 commentsModified the description in metadata for Not Generated NFT collection.
Modified file : $HOME/erc721-minting-boilerplate/src/components/ERC721Camera.jsx
Description of Not Generated #747 and earlier.
This is an photo taken with a camera whose shutter button is the Mint now button.
Description after Not Generated #748.
This is a photo taken with a camera whose shutter button is the Mint now button.
Human Controller
