I think the library is now at a point where you can use it for most of your applications. As of right now, it feature:
- Fix voltage and PPS voltage request
- Voltage reading
- Current reading
- NTC temperature reading
- Set parameter for NTC
Examples are included to cover most of the use cases that I can think of. Feel free to create an issue or comment here if you have any questions about your specific need.
Still missing the ability to edit Mask which will be updated soon. The library also does not support interrupt mode so there will be no self-feedback from the IC. I look forward to further testing.
Tested with:
- UGREEN 140W - PPS fully delivered <- Recommend
- RavPower 90W - No PPS
- Aergiatech 100W 4 Port - PPS does not work
CentyLab
