The system contains four main building blocks. I'll describe them next. I tried to be general in the terms, so I could decide on the details later, keeping the architecture relevant whatever I will decide to change later.
1 - The Main Controller
It consists of a Controller module and a CAN Module. The Controller uses GPIO to interact with the Cat Interaction Mechanism and the CAN module.
2 - Physical Transportation System
Also has a brain, interaction via CANbus with the main controller. Uses some physical transportation mechanism (wheels, legs, etc.) via an Interface module (e.g. a motor controller)
3 - Cat Interaction Mechanism
It is a mechanical device connected to the main controller. The interface module takes a logical commands (e.g. via GPIO configuration) and translates it to the mechanical movement
4 - Power System
A simple system of a power source and two lines:
- High-current - supplies the mechanical devices
- Low-current - supplies the logical devices
Andrei Gramakov
