And the last thing that we will need before start building a real thing. The logic.
The overall robot algorithm is the following:
The interaction between the robot components is described in the following sequence diagram:
Next time, finally, assembly of the first prototype and coding! We will add the other architectural details as we work.
Andrei Gramakov
