While I don't have photos of all these fixes, because I was rushing to get them "shipped" before delivering the PC back to my father, here's a list of things I fixed:
- Changed the "no connection" timer in the arduino sketch from a signed integer to an unsigned 32 bit integer. Hopefully that will fix the overflow issue, though the system never went without the app for enough time to confirm.
- As the node app had issues transmitting custom characters, I integrated an up arrow and a down arrow in the arduino sketch, to be used in the upload/download screen.
- On the node side, I made a helper function to better format the strings sent to the LCD. The function replaces the accented letters for their unicode elements (so é would become e´ ), which then I could remove easily. It also filtered any characters not in the valid range to avoid having weird characters in the screen.
With this, the project was finally ready for delivery.
Abraham Limpo
