Hackaday.io Hackaday.io
Sign up Log in
Home Climate Control
Hardware independent multi zone climate control system
vadim-tkachenkoVadim Tkachenko
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
Public Chat
0 comments
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 2
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
Public Chat
249
0
0
0
Team (1)
  • vadim-tkachenkoVadim Tkachenko
Join this project's team
  • Home Climate Control
Software
ongoing project
HVAC home automation ZIGBEE z-wave 1-wire xbee mqtt Android Remote control Climate control temperature zoning ventilation smart home observability influxdb ESP32 ESP8266
This project was created on 09/16/2023 and last updated 3 years ago.
Description
Create as many climates in your home as you never thought imaginable. Control temperature, humidity and ventilation. Do it on a schedule. Have everything measured and recorded. Do it from anywhere.
Project Logs
Collapse
  • Complete configuration guide published
    Vadim Tkachenko • 09/16/2023 at 21:24 • 0 comments
    Configuration was always the Achilles' heel of this project. Now that there is a new, simplified YAML configuration, it was a good idea to document it as it was being developed.
    The configuration guide is a part of the active development branch, it will not bit rot like other sites inevitably did. Here: https://github.com/home-climate-control/dz/blob/reactive/docs/configuration/index.md
  • 23 years from the start, finally, docs
    Vadim Tkachenko • 09/16/2023 at 21:22 • 0 comments
    https://github.com/home-climate-control/dz/blob/reactive/docs/index.md - published on the active development branch, will make it to the home page when the development iteration is complete
View all 2 project logs
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
This project aims to substitute the low quality hub to control milight / easybulb or limitlessled clones.
Project Owner Contributor
canny: ESP8266 + nRF24l01 milight gateway
djsbdjsb
The Bee Comfy is a MCU-based climate control system for honeybees
Bee Cage Climate Control
criptastichackerCriptasticHacker
Adding a WiFi, NTP and MQTT remote control & measurement unit to a storage heater.
IoT Storage Water Heater Control
keri-szafirKeri Szafir
Innotronics presents Innohome, the smart home automation system that is the ultimate life hack.
Innohome
sarahekairebsarahekaireb
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Home Climate Control", please tell us the reason.
Send message
Remove Member
