Physical Test
A project log for Custom Intellivision Controller
There have been many redesigns of the Intellivision controller. This is mine.
deftcoyotedeftcoyote • 10/30/2023 at 00:09•0 Comments
With a bit of debugging and some code tweaks I have a physical setup working.
List of features:
The code needed to be tweaked for a few reasons. First, I used different resistor values for the analog mapping of the keypad. I also added in a bunch of debug stuff for testing the physical implementation. Finally, I was getting inconsistent output from the joystick, which I fixed by simplifying the deadzone calculations from euclidean to manhattan distance. It's much simpler and faster. The deadzone is just more of a diamond than a circle.
Here's me pressing the control stick in a SW direction while pressing the '5' n the keypad. The joystick is outputting to controller 1 and the keypad s outputting to controller 2.
Now I need to do output testing on an actual intellivision and then I can start designing the circuit boards. I'm thinking of having a modular circuit board arrangement, and a modular controller arrangement to accommodate left/right players and single controller output.
