https://makertube.net/w/bufv9BJv2vcXDb3KUaksB7 / https://www.youtube.com/watch?v=CpP7KS1fbrY
`@ozoned@video.thepolarbear.co.uk` interviewed me on my home cockpit on a live stream via his Owncast instance at https://stream.ozoned.net/. This is a more condensed version of the stream that is still just 1h shy. We’re going over almost every feature of my Primary Buffer Panel and I explain how everything works. I also decided to add various photos, slideshows or video snippets during the talk only sections so things don’t get too boring. Sometimes that even complements the talks 😄
Ever wondered how to start your own DIY home cockpit / SimPit on? It’s easy. Just watch this stream 🤓
Dedicated project website: https://SimPit.dev
Check out the original recording if you want to see more or the full stream with more [dirty] details: https://video.thepolarbear.co.uk/w/9zNcweVw2fxxpSrmBnaQJa
Originally noted at: https://beko.famkos.net/2024/12/18/interview-in-depth-walkthrough-of-my-primary-buffer-panel/
Beko Pharm
