Firmware
A project log for A Tile Based MacroPad
Using "magic" tiles to assign keystrokes to this MacroPad's keys.
michael-gardiMichael Gardi • 10/02/2023 at 17:39•0 Comments
I have posted an initial version of the Arduino based firmware to GitHub. It handles the reading of the tiles, and assigns the macros to specific keys.  I'm using the Arduino HID-Project library to send the keys via USB to the PC. This is working well.
When I started looking at similar MacroPad projects, at least the ones that were not based on QMK or Kaleidoscope, I found that they were all virtually mapping keys directly to some code. For instance:
switch(button){
    case '1':  //Return
      Keyboard.press(KEY_RETURN);
      Keyboard.releaseAll();
      break;
    case '2':  //Escape
      Keyboard.press(KEY_ESC);
      break;
    default:
      break;
For every macro added or changed then the code would get modified. Not a big deal but it could be easier, especially maybe for non-programmers.  In my implementation the user can define the macros as comma delimited strings. Here are my macro definitions so far.
It starts with the definition of keyboard and media codes.
* Standard Key Codes.
KEY_RESERVED               KEY_ENTER                   KEY_PAGE_DOWN
KEY_ERROR_ROLLOVER         KEY_RETURN                  KEY_RIGHT_ARROW
KEY_POST_FAIL              KEY_ESC                     KEY_LEFT_ARROW
KEY_ERROR_UNDEFINED        KEY_BACKSPACE               KEY_DOWN_ARROW
KEY_A                      KEY_TAB                     KEY_UP_ARROW
KEY_B                      KEY_SPACE                   KEY_RIGHT
KEY_C                      KEY_MINUS                   KEY_LEFT
KEY_D                      KEY_EQUAL                   KEY_DOWN
KEY_E                      KEY_LEFT_BRACE              KEY_UP
KEY_F                      KEY_RIGHT_BRACE             KEY_NUM_LOCK
KEY_G                      KEY_BACKSLASH               KEYPAD_DIVIDE
KEY_H                      KEY_NON_US_NUM              KEYPAD_MULTIPLY
KEY_I                      KEY_SEMICOLON               KEYPAD_SUBTRACT
KEY_J                      KEY_QUOTE                   KEYPAD_ADD
KEY_K                      KEY_TILDE                   KEYPAD_ENTER
KEY_L                      KEY_COMMA                   KEYPAD_1
KEY_M                      KEY_PERIOD                  KEYPAD_2
KEY_N                      KEY_SLASH                   KEYPAD_3
KEY_O                      KEY_CAPS_LOCK               KEYPAD_4
KEY_P                      KEY_F1                      KEYPAD_5
KEY_Q                      KEY_F2                      KEYPAD_6
KEY_R                      KEY_F3                      KEYPAD_7
KEY_S                      KEY_F4                      KEYPAD_8
KEY_T                      KEY_F5                      KEYPAD_9
KEY_U                      KEY_F6                      KEYPAD_0
KEY_V                      KEY_F7                      KEYPAD_DOT
KEY_W                      KEY_F8                      KEY_NON_US
KEY_X                      KEY_F9                      KEY_APPLICATION
KEY_Y                      KEY_F10                     KEY_MENU
KEY_Z                      KEY_F11
KEY_1                      KEY_F12
KEY_2                      KEY_PRINT
KEY_3                      KEY_PRINTSCREEN
KEY_4                      KEY_SCROLL_LOCK
KEY_5                      KEY_PAUSE
KEY_6                      KEY_INSERT
KEY_7                      KEY_HOME
KEY_8                      KEY_PAGE_UP
KEY_9                      KEY_DELETE
KEY_0                      KEY_END
You can add any of these codes to the keyboard lists below for use in macro definitions.
In the keyboardKeyNames table add the code as a string delimited by "".
In the keyboardKeyCodes table ad the code as is without quotes.
Don't forget the commas at the end of each entry.
It is IMPORTANT to add the name and code in the same position in the list.
String keyboardKeyNames[] = {
  "KEY_LEFT_CTRL",
  "KEY_UP_ARROW",
  "KEY_DOWN_ARROW",
  "KEY_LEFT_ARROW",
  "KEY_RIGHT_ARROW"
KeyboardKeycode keyboardKeyCodes[] {
  KEY_LEFT_CTRL,
  KEY_UP_ARROW,
  KEY_DOWN_ARROW,
  KEY_LEFT_ARROW,
  KEY_RIGHT_ARROW
* Media Key Codes.
MEDIA_RECORD             MEDIA_VOLUME_MUTE
MEDIA_FAST_FORWARD       MEDIA_VOL_MUTE
MEDIA_REWIND             MEDIA_VOLUME_UP
MEDIA_NEXT               MEDIA_VOL_UP
MEDIA_PREVIOUS           MEDIA_VOLUME_DOWN
MEDIA_PREV               MEDIA_VOL_DOWN
MEDIA_STOP
MEDIA_PLAY_PAUSE
MEDIA_PAUSE
You can add any of these codes to the media lists below for use in macro definitions.
In the consumerKeyNames table add the code as a string delimited by "".
In the consumerKeyCodes table ad the code as is without quotes.
String consumerKeyNames[] = {
  "MEDIA_PLAY_PAUSE",
  "MEDIA_VOL_MUTE",
  "MEDIA_VOLUME_UP",
  "MEDIA_VOLUME_DOWN"
ConsumerKeycode consumerKeyCodes[]{
  MEDIA_PLAY_PAUSE,
  MEDIA_VOL_MUTE,
  MEDIA_VOLUME_UP,
  MEDIA_VOLUME_DOWN
* Define the macros here.
String macros[] = {
  "PRESS,KEY_LEFT_CTRL,a,RELEASE_ALL",  // select
  "PRESS,KEY_LEFT_CTRL,c,RELEASE_ALL",  // copy
  "PRESS,KEY_LEFT_CTRL,x,RELEASE_ALL",  // cut
  "PRESS,KEY_LEFT_CTRL,v,RELEASE_ALL",  // paste
  "KEY_UP_ARROW",                       // up
  "KEY_LEFT_ARROW",                     // left
  "KEY_RIGHT_ARROW",                    // right
  "KEY_DOWN_ARROW",                     // down
  "",                                   // Skip for now.
  "MEDIA_VOLUME_DOWN",                  // louder
  "MEDIA_VOLUME_UP",                    // softer
  "MEDIA_VOL_MUTE",                     // mute
  "MEDIA_PLAY_PAUSE",                   // pause/play
When a  key on the pad is pressed, it's corresponding tile is read to get the tile number. This number is used as an index into the macros table to get the appropriate macro string which is parsed to determine the keys to send to the PC. The macro string is split into "tokens" at the commas and the tokens are processed from left to right with the following rules:
  1. If the token is  "PRESS", a flag is set to to indicate that all subsequent characters (c) will be sent with the Keyboard.press(c) function. If the press token is not set (default at start of parsing), characters will be sent with Keyboard.write(c).
  2. If the token starts with "KEY_", then the token is used to lookup a keycode in the keyboardKeyCodes table. That keycode is sent to the PC via the Keyboard press or write functions depending on the press flag.
  3. If the token starts with "MEDIA_", then the token is used to lookup a keycode in the consumerKeyCodes table. That keycode is sent to the PC via the Consumer press or write functions depending on the press flag.
  4. If the token is "RELEASE", then a release flag is set. The next character processed (c) will be sent to the PC with a Keyboard.release(c) function and the release flag will be cleared.
  5. If the token is "RELEASE_ALL", then the Keyboard.releaseAll() function will be executed and the release flag cleared.
  6. If the token is a hex digit of the form "0xnn" exactly where nn is a valid hex number, then the value based on that number will be sent to the PC via the Keyboard press or write depending on the press flag.
  7. If the token is not recognized as one of the "key words" above, then it’s assumed to be an ASCII character or a string. If the token is a single character it will  be sent to the PC via the Keyboard press or write depending on the press flag. If it's a string (s) it will be sent to the PC with a Keyboard.print(s) call. (NOTE there is no corresponding Keyboard.println(s) call because the user can simply add a \n to the end of the string if that is what they want.)
So someone could define the macros within this code without knowing any programming. Mind you to get the firmware onto the pro Micro they will still have to, at a minimum, learn the Arduino IDE.
