1Step 1
The main idea is to take off the speaker, but leave the cables to use them for the coil.
2Step 2
Make a coil with at least 50 turns of wire in a space of 1 1/2 inches of more.
3Step 3
Adapt the coil sides to the speakers cables, not matter if it is ground or power side.
4Step 4
Download the code, and compile it: g++ AudioSpoof.c and run it: ./a.out
5Step 5
./a.out will generate a .wav file, turn on the wireless speaker and connect it.
In the terminal play the file that you just created it: play -r 8192 audiospoof.wav repeat 2
6Step 6
Make sure that you adjust the volume, or add repeats to de play command for better results.
Salvador Mendoza
