Concept
My last PC was very noisy and old so I had the dream to build a complete passive PC. After some search I thought that it schould be possible. Follow the logs to see how I finally succeeded. Let's start with some interessting links I found in the internet:
- Asian description of an alike build: link
- Companies offering passive PCs: e.g. link, link
- A nice YouTube channel: link
- A german project in a forum: link
In my build I did not use an external graphics card and relied only on the build in capbabilities of the AMD Ryzen 7 which I also found to be very power efficient. For my kind of applications this is absolutely sufficient.
Component & cost estimate (2023)
This list should give you an overview about the components used and the cost associated. I did not counted the shipping costs nor the heatpipes I scrapped in between :-)
- PC Electronic Components
- CPU: AMD 7 Ryzen 7700x
- Motherboard: asus prime 650m-a wifi
- RAM: G.Skill Flare X5 schwarz DIMM Kit 32GB
- SSD: KINGSTON SFYRD2000G + Passive Cooler
- Silverstone SST-NJ700-80-Plus-Titanium
- DVD: HL-DT-ST DVDRAM GTC2N
- USB Front Pannel: GG 18019 Card Reader, intern, 3,5", USB 3.1, SD, Micro SD
- Graphic Card: none, used internal graphics
- Housing & Cooler (~250€)
- 2x Coolers (~90€, found on ebay incl shipping)
- 5x 6mm Heatpipes [400mm and 300mm] (35€ plus shipping) possible source
- 10x (10mmx20mmx5mm) + 2x Copper (60mmx50mmx10mm) blocks for heat pipe mount to cooler and CPU respectively (40€ plus shipping) possible on ebay
- Alu profiles (20mmx20mm, ~6m) and mounting angles (~45€ plus shipping) possible source
- Smaller stuff:
- alu blades for mounting (was scrap lying arround)
- Thermal paste (10€)
- Generic screws, us screws for CPU copper block mount and distance bolts (5€)
- Additional mini Alu Cooler fro CPU (8€)
- SlimDVD adapter cable
- Reset/Power Button
- T measurement setup (used only for debugging)
- Arduino Nano
- 5x T-sensors
- Box (2€)
Some PICs of my final full passive AMD Ryzen 7 7700X PC setup
reaching nearly 20.000pnts on cinebench R23
And the benchmark results are at least as good as teh benchmark found in the internet.
Lessons Learnt:
- The orientation of the CPU towards the mounting points of the heat pipes seams to be important. CPU should be below (gravity) the mounting points on the cooler.
- Be carefull+carfull+carefull when bending the pipes
BastelBaus
Sepio
mr. mosby
