The housing by alu profiles and two massive alu ribbon coolers
A project log for Full Passive AMD Ryzen 7 7700x DIY build
DIY build using heatpipes and two massive 300mm x 235mm x 75mm ribbed cooler blocks to form a zero noise passive cooled PC
bastelbausBastelBaus • 10/16/2023 at 21:09•0 Comments
Before I ordered the parts and started the build, I draw a rough 3D scetch of the build to get an idea of the dimensions.
After the cooler and the aluminium profiles (20x20) arrived, the build started:
Building the frame from teh profiles (Note; the initial plan was to have the PC standing like this but finally I removed the lower part and put the PC flat on teh floor, see late rblog posts):
