Signing Race !
This project is a video game with a custom controller made for it
The game is an office simulator, the player has to sign as many documents as possible, each document has a particular signature to make in a 3 x 3 grid, the player has to make as many signatures as possible in a given time. The controller is specially designed for this game, resembling a sheet of paper, and the player uses a fake pen to interact with it.
The game can be found here : https://nasser404.itch.io/signing-race
acrylic_sheet.svg
svg+xml - 4.13 kB - 01/04/2024 at 21:07
Preview
wood_box.svg
svg+xml - 6.09 kB - 01/04/2024 at 21:07
Preview
stamp_body.stl
Standard Tesselated Geometry - 264.24 kB - 01/04/2024 at 21:01
Download
stamp_shell.stl
Standard Tesselated Geometry - 216.49 kB - 01/04/2024 at 21:01
Download
stamp_support.stl
Standard Tesselated Geometry - 63.85 kB - 01/04/2024 at 21:01
Download
View all 6 files
  • 1 × arduino nano
  • 1 × wooded sheet (thickness 3mm) to make a box with laser cut
  • 1 × brass sheet (thickness 0.1mm) cut (5*5cm) to do the 3*3 matrice
  • 1 × acrylic sheet The top of the box
  • 2 × spring (1cm diameter and 5cm long) for the stamp
View all 8 components
  • Session 4
    joon-ho.kim01/08/2024 at 14:31 0 comments
    We changed our minds about the box. Instead, we used 3mm-thick wood and laser-cut it.
    For the plates, we cut the brass plates to 5cm by 5cm. On the box we cut an acrylic plate and made 9 holes for the plates.
    We placed in the box 9 neopixels to make the controller more satisfying.
    we weld all the brass plate in a pin of the arduino and we weld all the neopixels together to connect this in one pin of the arduino.
    We also made the pen. In the pen we just put a round metal piece to make the contact of this piece of metal and the brass plate to makee the sign.
    In this pen we have also a button that permit to change the color of the pen.
    And finally, the stamper.
    We just 3D printed the stamper and when we actionned the stamper, this will touch a button and it will pass all the bad CV.
  • Session 3
    Nasser11/21/2023 at 15:36 0 comments
    We tried to create a prototype of the controller, showing the basic functionality, and had it interact with our game via an arduino.
    We then made a list of materials and parts to buy for the final rendering.
    We also made a 3D model of the first part of the controller to better understand what will go where.
  • Session 2
    Nasser10/24/2023 at 14:01 0 comments
    We futher discusses design and materials to use
    We also started planning our project
  • SESSION 1
    Nasser10/17/2023 at 13:57 0 comments
    WE did the planning and the design
View all 4 project logs
  • 1
    To make the box controller
    Take the wood plate of 3mm thickness and laser cut it (we put the image in the file)
    Take also the acrylic sheet and laser cut it (we put the image in the file)
  • 2
    Make the stamper
    3D Print all the pieces ( in the files )
    put two spring inside the stamper.
    Puts all the pieces together.
    put a button (connected to the GND and a pin)
  • 3
    Make the pen
    Take a basic pen
    put a round piece of metal on the tip of the pen connected to a pin
    put a button in the pen (connected to the GND and a pin)
View all 7 instructions
