Our project is a alternative controler to play Mario kart PC. For the differents moves, we thought a lot and came with many ideas. There are 4 importants moves :
1) the directions,
2) use an object,
3) put the object frontward/backward
4) jump.
For the move 2, the idea is to use a plush and a pressure sensor . The idea is that the player have to press the plush to use an object and we add an sound when he press it.
For the move 3, the idea was to use a joystick like a gear lever but bigger and the system 2 will be on top. So when you want to put the object frontward, you push the stick frontward but it is to simple.
So the final idea is to use a presence sensor and the plush attached with a string to the hand, the player throw the plush to a dedicate zone to put the object frontward (a light turn on when it's done).
For the move 1, to move frontward/backward, the first idea was to use a real pedal systems and a toggle switch. The idea was to fix a stick in the chain so that when you pedal the stick activate the switch to move. But the pedal system is to complex and the stick might getting stuck in the mecanism. So we decide to keep the idea but built our own pedal system simplified, we will see how it will stand later.
Finally we decided to stop the pedal system because it is too difficult to make it and we don't have much time to finish the project so we change the bike 's pedal system by "car pedals". Our car pedals will be use with light sensor so the player will have to push a cardboard to activate the sensor and then move forward.
Also for the move 1, to go left/right, the idea is to use a steering car and tilt sensor fixed on it so when you tilt the steering car you activate the tilt sensor. We also decided to make our own steering car in 3D printing.
We started the code for the move 3 thanks to Tinkercad but we have a problem with the light.
