1Step 1
TSOC_PSoC4L Instructions
The TSOC_PSoC4L comes preprogrammed with a command line interpreter (CLI) that runs on the enumerated USB COM port by default. It can be changed to run onother ports interactively.
Immediately after plugging in the USB or Li-Po battery power the TSOC_PSoC4L will :
1) Runs a USB bootloader for ten (10) seconds to allow you to update the firmware. Use the Cypress Bootloader Host to load new firmware into the device to customize it.
2) Runs the RSVP command line interpreter with the following commands :
- commands : display the list of currenyl available commands
- info : display the firmware revision number and other board details
- echo : echo the current command
- test adc : display all current ADC channel values
- test uart : sends test string to all UART ports
- test boot : run the bootloader
- console x : changes the console to port "X"
- connect x y : connect port x to port y until the user button is pressed to exit
where : X (Y) = 0 - USB Port 1 - UART1 Port 2 - UART2 Port 3 - I2C1 Port 4 - I2C2 Port 5 - SPI1 Port 6 - SPI2 Port
2Step 2
Other Applications
The TSOC_PSoC4L can also drive other devices, such as Servos, Motors, Relays and more. This requires custom firmware at the current time.
** If you would like to help with firmware development, please send us a request, and we'll get you on the list for board shipments.
