Newer version
A project log for Esp32-Stick-Cam(Esp32-S3+Active/PassivePoE+Camera)
And upgraded version of the Esp32-Stick with Camera/Ethernet/Poe support based around the Esp32-S3 chip
allexokallexoK • 09/01/2025 at 20:42•0 Comments
I've recently made a new board based around Esp32-PoE-A-Cam with SD card, battery management and Lora (with shield ) supported: https://hackaday.io/project/203879-ai-on-the-edge-cam
The new version is made mainly for Ai-On-The-Edge-Device framework, but can be used with custom firmware too.
Curious if Micropython/Circuitpython would work
