Newer version
09/01/2025 at 20:42 • 0 commentsI've recently made a new board based around Esp32-PoE-A-Cam with SD card, battery management and Lora (with shield ) supported: https://hackaday.io/project/203879-ai-on-the-edge-cam
The new version is made mainly for Ai-On-The-Edge-Device framework, but can be used with custom firmware too.
Curious if Micropython/Circuitpython would work
Big batch arrived, Easter sale
03/16/2024 at 15:04 • 0 commentsThe bigger batch has finally arrived and is now available for purchase on Tindie. Additionally, to make the boards more accessible, I've decided to launch an Easter sale!
Bigger batch manufacturing and ESPHome support
01/13/2024 at 16:32 • 0 commentsHello everyone, long time no see.
The year 2024 has recently begun and it's time to push the project a little further! I received many positive feedback about the boards and people seem to be satisfied, so I will be making bigger batch in February(100 pcs of PoE-A and PoE-P boards).
One customer pointed out to me that the PSRAM may be unavailable when using the Ethernet, because they share the same pins. In the newer version this bug will be fixed.
I also got the YAML(Thanks to my friend Vít Petrák) for ESPHome, you can check it out here. The YAML demonstrates the Ethernet and Camera usage and can help you to connect the board to Home Assistant.
Stay tuned!
Alex
allexoK
