Following changes required to version 1 of the Display enclosure.
- minimize standoff height
- make walls to extend to the LED strip and OLED display
- reduce wall thickness on LED strip standoffs on board side for clearance
- move USB hole away from face
- redesign the buttons
- reduce OLED hole in width and height
Holes in standoff etc work well for 2mm and at least a few turns of 2.3mm
Used 2x5mm for LED to enclosure and 2.3 x 10mm for two holes of the Feather/Wing to the enclosure. Really need longer 12mm or 14mm.
Enclosure is serviceable as is. See photos. (Note: I did not yet install the side switch for power)
tklenke
