Connected(ish) to plotly
A project log for 1Charger
OneCharger to rule them all; solar-panel, TEG, dynamo...
mrjbmr.jb 08/04/2014 at 21:420 Comments
It is very easy to make a charge curves with multicharger....
Update the following defines in mcharger.c ( and then make and flash ;-)
#define SOFTWARE_UART
Plotly works best with a date specified which also makes it easier to keep track of charge curves and allow comparison with weather stations. I started using a hard coded date and later made a utility called log2plotly.
Connect a usb to serial 3.3V to PA7 and GND and start Tera Term ( or other simple serial devices like OpenLog, ESP8266, HC-05 Bluetooth ). Then choose a log-file. When charging is complete, import file to Plotly.
1. fast charging 8Ah LiFePO4 curve (no electron left behind ;-)
2. fast charging A123 2Ah curve
