Done.
A project log for D1 Mini X-Pad Shield
Adds some buttons to your ESP8266 board.
dehipudeʃhipu 01/25/2017 at 12:032 Comments
The PCB arrived from OSHPark, and it works. You can order it at: https://oshpark.com/shared_projects/J8a9MVbO
I'm not happy with the buttons -- I used some cheap SMD buttons that I had on hand, but they are not really designed for being pushed directly by fingers. I might try gluing something on top of them, so they work better.
I used a chip socket for the chip, and the whole thing is rather high. In the future, I would probably use a different chip, in SMD version, and maybe even put it on the bottom.
All in all, it works well enough and I'm quite happy with it.
davedarko wrote 01/25/2017 at 12:56 point
now remove all the headers, add the LCD shield and a LiPo shield, swap the dip to a soic footprint and make a sweet tiny little "gameboy" :) or at least stack them and take a picture of it :)
I really like the form and flow of this board!
deʃhipu wrote 01/25/2017 at 16:42 point
Yeah, that's the direction I'm going, slowly, but the hard part is the software. So in the mean time I make the parts I need for it as separate things, re-usable for other stuff in case I fail miserably. If I ever pull it off, I will make a proper PCB.
