Some prototyping fun & relaxing soldering
A project log for GinScope | Science ToolBox | Oscilloscope
Is there room for another oscilloscope? Real Time nodejs/html5 Sci ToolBox! Arduino | Raspberry Pi | FPGA
Gintaras ValatkaGintaras Valatka 07/15/2017 at 09:140 Comments
Running same coax to 5v relays.
Separate grounds, planning to switch single ended/differential
Unleaded started appearing all over the place
Identified, fixed
clingFilm+rubberBand
Attaching balanced microphone cables between relays & ADC connector, to make it more flexible and less fragile than coax (no buffer this time) AC/DC caps soldered on the other side
Trying to keep the inputs short and sweet
ADC DIP sockets, some headers, connections & secret markings :S
Something is brewing, picking up noise, might be relays
With faster ADCs will be making proper PCBs this is just some playtime
Can you spot RGB LED LDR variable resistor, controllable via PWM? more:
https://hackaday.io/project/21480-ldr-pot-making-matching-plotting
