Hackaday.io Hackaday.io
Sign up Log in
Converter from USB to 4 isolated UARTs
Cheap isolated USB to 4 UARTs converter
miroslav-hancarMiroslav Hancar
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
3 followers
  • Description
  • Details
  • Files 2
    • View all
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
431
0
3
1
Team (1)
  • miroslav-hancarMiroslav Hancar
Join this project's team
completed project
hardware
USB to UART CONVERTER ISOLATED CH340 ch334 hub usb
This project was created on 11/24/2023 and last updated 3 years ago.
Description
This simple converter is built on cheap chinese components. It is connected to a PC via a USB-B connector followed by an ESD protection USBLC6-2SC6. The 5V USB power supply is protected from power surges or short circuits by a MT9700 (or BL2554) current limiter with a limit set at 1.5A. Four CH340C USB to UART converters are connected to the four-channel USB hub CH334U, which are enumerated as virtual COM ports when connected to a PC. The RX, TX, CTS and RTS signals are transferred to the output terminals by capacitive isolators π122M31. The isolated side of the converters is powered by isolated DC-DC converters IVB0105S3V3.
Details
Files
iso_converter_kicad.rar
KiCad files
x-compressed - 279.39 kB - 11/24/2023 at 13:02
Download
production.zip
Production files
x-zip-compressed - 323.16 kB - 11/24/2023 at 13:00
Download
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
industrial grade bi-directional high speed USB powered isolated USB to UART converter
Project Owner Contributor
dinanaDinana
Got sick of my old, outdated navi that came with the car so I used an Android tablet to make a new one.
Nexus 7 (2012) In-Dash Install
equinnoxxEquinnoxX
Transform your old power supply into a modern USB-C fast charging adapter.
IP6520 USB PD Source
stefan-wagnerStefan Wagner
Get 5V,3.3V from USB with overcurrent protection
Easy USB Supply
kuldeep-singh-dhakaKuldeep Singh Dhaka
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Converter from USB to 4 isolated UARTs", please tell us the reason.
Send message
Remove Member
