Adding mounting holes V1.1
A project log for USB PD Trigger SuperCharged with PPS!
A much simplified USB-C PD and PPS trigger board. Allow users to select arbitrary voltage from PPS-capable power brick via potentiometer
centylabCentyLab 02/13/2024 at 05:000 Comments
The newer version of the PPSTrigger board now features half-cut mounting holes. This will fit your standard M2 screw or bolt. No more gluing your circuit to your 3D-printed enclosure.
The new board also features a new LDO that has better ESD protection than the previous selection.
