CreeRead.mp4Demonstration of the project. The Cree board is connect to a Staples Connect home automation hub, on the right. The Arduino serial terminal is on the left. You can see the output from the Arduino as I change the settings on the bulb.MPEG-4 Video - 1.55 MB - 01/14/2017 at 03:16 |
CreeBoardRead.inoArduino sketch to read Cree dimmer level.ino - 3.27 kB - 01/14/2017 at 02:30 |
data.txtRaw data for voltage levels read on the Arduino analog pin.plain - 215.76 kB - 01/12/2017 at 21:33 |
