Hackaday.io Hackaday.io
Sign up Log in
STAR Autonomous Suture Tension Management Device
This device attaches to the end effector of the Smart Tissue Autonomous Robot (STAR) and allows for autonomous suture tension management
nyeli-kratzNyeli Kratz
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
2 followers
  • Description
  • Details
  • Files 4
    • View all
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
315
0
2
4
Team (1)
  • nyeli-kratzNyeli Kratz
Join this project's team
shelved project
hardware
This project was created on 12/21/2023 and last updated 3 年前.
Description
We developed a device which attaches to the end effector of the Smart Tissue Autonomous Robot (STAR) and allows for autonomous suture tensioning management. This design could be used for fully autonomous suturing within a laparoscopic environment. Increasing the level of autonomy in surgical robotic systems will help to standardize patient outcomes and free up surgeons for other tasks. Striving for higher levels of autonomy could be particularly useful in time-consuming and repetitive tasks such as suturing. Our design is held in place at rest by a torsion spring at the pin joint which allows the device to sweep forwards to pull tension on the thread and then return to its resting position to avoid interference with STAR’s suturing mechanism using only one motor. The device is cable-driven so that the motor can remain outside of the body and has a maximum diameter of 24mm to allow it to fit into a trocar.
Details
Files
Final Report Team 11.pdf
Project Report
Adobe Portable Document Format - 5.24 MB - 12/21/2023 at 14:39
Preview
SMD_v41_stp.zip
End effector CAD files
x-zip-compressed - 1.12 MB - 12/21/2023 at 14:38
Download
spool.STL
spool CAD file
Standard Tesselated Geometry - 507.60 kB - 12/21/2023 at 14:38
Download
cisii_poster_TEAM11.pptx.pdf
Project poster
Adobe Portable Document Format - 1.43 MB - 12/21/2023 at 14:37
Preview
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
Official Hackaday Prize Entry
Uses Bluetooth 4.0 and a coin cell battery to detect when you leave your sunglasses somewhere other than your car or home.
Project Owner Contributor
BLE Proximity Alarm for Sunglasses
daniel-youngDaniel Young
A VR Locomotion device utilizing simple robotic arms
Robotic Arm VR Locomotion Device
finallyfunctionalfinallyfunctional
A wearable device that helps prevent you from touching your face.
COVID-19 Wrist Alarm
alexAlex
Silence the speaker in the Owlet Smart/Dream Sock base station
Hush Owlet
mikeMike
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "STAR Autonomous Suture Tension Management Device", please tell us the reason.
Send message
Remove Member
