I've implemented an algorithm for colour classification that seems to work ok:
- detect brightness changes from below to above threshold, i.e. a piece arrives at the sensor
- each sample is matched to nearest colour in a library of about 30, using 'redmean' distance
- wait until M out of the last N samples are the same (because the detected colour can change significantly as the piece arrives and as it leaves the sensor, where it's only partly in the field of view)
- determine output bin and move diverter
- wait small fixed delay for piece to fall down diverter
- repeat.
This seems to work ok for big bricks, but small pieces will be a problem because they are moving too quickly to get more than 2 or 3 samples total, so the "M out of N" consistency check will fail. This is exacerbated by using a fixed (non-vibrating) section of feeder which needs to be at a fairly steep angle to ensure pieces don't stop, but means they're moving pretty fast by the time they reach the sensor:
- smallest piece/dimension: 8mm
- max. speed of travel along feeder: 0.8m/s
- min. time passing sensor: 8mm / 800mm/s = 10ms.
- sensor rate: 5ms/sample (including processing)
- min. number of samples: 10 / 5 = 2
But it works well enough as a starting point:
An alternative plan I'll try next is to position a second light sensor above the feeder, trained to detect the light from the illuminating LED. When the light dims sufficiently, we can be pretty sure there's a piece in just the right place, so should be able to exactly time a single colour measurement (taking only 5msec) rather than needing a whole string of them. [Update: yes this approach works very well! More to follow in next log.]
