Hi! i made a project automating my antique heating system by adding an Esp32 in parallel to the original mechanical thermostat.
I use Node-red for logic and data aggregation, running on Raspberry Pi to automate an relay controlled by Esp32.
I store every variable in a time-series database an display it using Grafana.
mugur
Kevin Kingsbury
aerospark
SAYANTAN PAL
Costin Stroie
