This is my collected data from Aliexpress inductors I have in my parts bin. The link displays the oscilloscope screen shot for that inductor test.
The worst inductors where the SMD 1210 sized inductors, which probably were not meant for switching power applications. The best inductors were labeled Molded Power Inductors, and the saturation current measurements were really rough, since the current was so high, the voltage drop across the P-Channel FET becomes an issue. These "molded inductors" curves looks a lot like the metal alloy Bourn ones I got from Digikey, so they are probably the best choice for the power applications.
| Inductor Name | Picture | Results | ||||||||||||||||||
| CDRH74R 7.3mm x 7.3mm |
| Through Hole 4mm x 6mm |
| Through Hole 8mm x 10mm |
| Axial Through Hole |
| SMD 3.5mm x 3.5mm | 1mH released the magic smoke. Apparently the maximum current this device can handle is less than the saturation current. | |||||||||||||||||||
| CD43 4mm x 4.3mm |
| SMD 1210 2.5mm x 3.75mm |
| 0402 Molded Power Inductor 4mm x 4.5mm |
| 0520 Molded Power Inductor 5.5mm x 5.0mm |
| 0650 Molded Power Inductor 6.5mm x 6.5mm |
| 1040 Molded Power Inductor 10mm x 10.4mm |
Kevin Kessler
