Solid State Tank is an Eink wrist watch inspired by CW&T solid state watch.
The watch uses a custom made segmented eink display with half scale DSKY digits.
The consumption is sub 500nA at 3V and the system is powered by a CR1616.
The whole watch is encased in clear epoxy.
Detailed writeups of the build:
https://www.0xam.com/blog/solid-state-tank-part-1-eink-watch-sub-500na3v
https://www.0xam.com/blog/solid-state-tank-part-2-assembling-the-watch
Hi!, Thanks for the comment. I delaminated one e-reader screen (you have to buy old models as newer ones don't delaminate) and then laminated the eink portion to the PCB using heat and UV curable clear epoxy to seal the edges. More info here: https://www.0xam.com/blog/diy-e-ink-part-1-delaminating-the-screen and https://www.0xam.com/blog/diy-e-ink-part-2-testing-the-screen
Nice work, I saw more details here
