Stop Using Batteries
A project log for Custom Display for Elliptical Trainer
Buy a cheap exercise device, get cheap display. But we can fix this!
mike-szczysMike Szczys 01/15/2017 at 19:380 Comments
The first thing I did to this was to get rid of batteries. I used some scrap wood with a screw in the end for a battery stand-in. Here you can see the positive and negative connections made in the original battery slots. The only alteration to the exercise machine is a slot cut in the battery lid for the wire from the wall wart to exit.
